Philco 80 Jr, just starting....
Threads: 55
City: Lexington, KY
If you use too large of a capacitor as the first electrolytic then you risk stressing the rectifier and transformer (higher B+). As LASJayhawk mentioned, I don't think those 16uF caps are original to your set. The other issue you have to consider is the line voltage is higher today, also contributing to higher B+ (stress on the rectifier and transformer).
Capacitors are fairly cheap and I'd just buy a handful of 10uF's to have in stock.
http://www.oldradioparts.net/caps_lytic.html
(This post was last modified: 02-27-2012, 01:45 PM by Eliot Ness.)
Re: Philco 80 Jr, just starting.... - by Eliot Ness - 02-13-2012, 10:31 AM
>>and found that the field coil is bad. Should be 1140 ohms, tests at 1.1k ohms.
You have one stringent crit...morzh — 02:07 PM |
Yes I was there. I got some real bargains there. Plus a Zenith 7G605 clipper that I have been trying to find for a fair ...Radios1340 — 01:46 PM |
The speaker table error?
G 10-1/2" 65, 76, 87, 95
Push-Pull 45's
2766
0.7
550
3200
H 10-1/2" 77, 96
Push-Pull...morzh — 09:26 PM |
I have a Stromberg, one of the early ones, seems early 30s.
This is what I call a back breaker. None of the early Philc...morzh — 08:28 PM |
A backbreaker.....PaulPaul Philco322 — 08:12 PM |
>>What a behemoth!
A Juggernaut.morzh — 07:47 PM |
Philco 70 antenna lead
I am not sure I understood about the coils and the mush. I looked an more than one coil in 20, 70, 90, 60, Zeniths and ...morzh — 07:46 PM |
:e_biggrin: What a behemoth! I hope the final result is as much a quality sounding example! Keep us posted on your pro...GarySP — 07:32 PM |
I should add that the double conversion may only be used on the shortwave bands, but I haven't looked at the schematic t...Arran — 07:27 PM |
Yes, that wire will not pick up much interference as routed - the RF at that level won't be affected, and if you have st...radio1 — 07:26 PM |
There are currently 7328 online users. [Complete List] » 3 Member(s) | 7325 Guest(s)
