Set screw removal
I use needle nose pliers as well, works just fine. Why bother with a tool that serves only one function in life when you already have a tool that can do so much more? That's just my two cents worth.
Dave
Set screw removal - by billp - 02-12-2012, 04:04 PM
Re: Set screw removal - by Ron Ramirez - 02-12-2012, 07:32 PM
Re: Set screw removal - by codefox1 - 02-13-2012, 04:28 PM
Re: Set screw removal - by Dave - 02-13-2012, 10:11 PM
Re: Set screw removal - by ipwizard - 02-14-2012, 04:44 PM
Re: Set screw removal - by billp - 02-14-2012, 05:26 PM
Re: Set screw removal - by LASJayhawk - 02-14-2012, 07:32 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7624 online users. [Complete List]
» 3 Member(s) | 7621 Guest(s)
