Is this a xformer quick fix?
Sounds like it. Measure the resistance of the coil.
Is this a xformer quick fix? - by DKinYORKpa - 02-13-2012, 07:01 PM
Re: Is this a xformer quick fix? - by 7estatdef - 02-13-2012, 11:02 PM
Re: Is this a xformer quick fix? - by DKinYORKpa - 02-14-2012, 08:49 AM
Re: Is this a xformer quick fix? - by DKinYORKpa - 02-14-2012, 09:05 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6906 online users. [Complete List]
» 1 Member(s) | 6905 Guest(s)
