Is this a xformer quick fix?
It's open. I sent Ron a coil rewind request.
Is this a xformer quick fix? - by DKinYORKpa - 02-13-2012, 07:01 PM
Re: Is this a xformer quick fix? - by 7estatdef - 02-13-2012, 11:02 PM
Re: Is this a xformer quick fix? - by DKinYORKpa - 02-14-2012, 08:49 AM
Re: Is this a xformer quick fix? - by DKinYORKpa - 02-14-2012, 09:05 PM
The speaker table error?
Philco 70 antenna lead
