Request: Where to Install A Fuze Holder
Good morning, all. I've done a ton of work rewiring the Philco 39-30 Code 121 because of rotted rubber-coated wiring and want to protect the set.
I've gotten answers to questions on putting in Safety caps inside the Bakelite cap, but where is the best location to put a fuze into the circuit?
Regards,
Clarence
Request: Where to Install A Fuze Holder - by imacdaddy757 - 02-15-2012, 07:45 AM
The speaker table error?
Philco 70 antenna lead
