Bakelite Condenser 3903-DG
I show a 3903-DG as a dual 0.01 uf cap:
O-| | |
.. 1 2 3
#1 is ground and one end of both caps
#2 is cap 1
#3 is cap 2
John
Las Vegas, NV USA
Bakelite Condenser 3903-DG - by imacdaddy757 - 02-15-2012, 08:27 AM
RE: Bakelite Condenser 3903-DG - by morzh - 05-04-2012, 02:02 PM
Re: Bakelite Condenser 3903-DG - by LASJayhawk - 02-15-2012, 12:02 PM
Re: Bakelite Condenser 3903-DG - by Ron Ramirez - 02-15-2012, 12:27 PM
Re: Bakelite Condenser 3903-DG - by DeckApe - 02-15-2012, 07:00 PM
Re: Bakelite Condenser 3903-DG - by imacdaddy757 - 02-15-2012, 07:46 PM
RE: Bakelite Condenser 3903-DG - by imacdaddy757 - 05-04-2012, 07:34 AM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 7621 online users. [Complete List]
» 1 Member(s) | 7620 Guest(s)
