Philco 38-7 dial lamp
The brass ring (glass cover) will pop out after a slight twist CCW. Pry up carefully.
Remove the snap ring around the circumference of the dial scale.
The dial pointer will pull off and is keyed for reference.
Next carefully pop out the dial scale allowing access to the no. 44 bulb.
Richard
Philco 38-7 dial lamp - by joejoe - 02-11-2012, 03:18 AM
Re: Philco 38-7 dial lamp - by rghines1 - 02-16-2012, 11:24 AM
RE: Philco 38-7 dial lamp - by joejoe - 02-27-2012, 01:41 AM
RE: Philco 38-7 dial lamp - by rghines1 - 02-27-2012, 07:44 AM
The speaker table error?
Philco 70 antenna lead
There are currently 7687 online users. [Complete List]
» 2 Member(s) | 7685 Guest(s)
