  • 3 Vote(s) - 1.33 Average
Magnetic tuning and Shadowgraph
Hi Terry
The 37-675 Standard also used a shadowmeter and Magnetic Tuning, but no automatic tuning mechanism.
There were some 1938 models that used a shadowmeter. None of these had Magnetic Tuning, though.
Magnetic tuning and Shadowgraph - by 7estatdef - 02-26-2012, 05:14 PM
RE: Magnetic tuning and Shadowgraph - by Ron Ramirez - 02-26-2012, 06:00 PM
Philco 91 Tuning Condenser
