Philco 38-7 dial lamp
(02-16-2012, 11:24 AM)rghines1 Wrote:  The brass ring (glass cover) will pop out after a slight twist CCW. Pry up carefully.
Remove the snap ring around the circumference of the dial scale.
The dial pointer will pull off and is keyed for reference.
Next carefully pop out the dial scale allowing access to the no. 44 bulb.
Richard
Richard,
I just got back on the this site to check this posting. Thanks very much for your help. It's late right now; however, tomorrow I will get back to the radio.
The radio works find, except for this dial lamp.
The cabinet is almost complete and it will look much better when this dial lamp is replaced.
Once again, thank you very much for your help.
Philco 38-7 dial lamp - by joejoe - 02-11-2012, 03:18 AM
Re: Philco 38-7 dial lamp - by rghines1 - 02-16-2012, 11:24 AM
RE: Philco 38-7 dial lamp - by joejoe - 02-27-2012, 01:41 AM
RE: Philco 38-7 dial lamp - by rghines1 - 02-27-2012, 07:44 AM
The speaker table error?
Philco 70 antenna lead
There are currently 7612 online users. [Complete List]
» 3 Member(s) | 7609 Guest(s)
