Philco 1934 Model 60mb
(02-27-2012, 11:23 PM)7estatdef Wrote:
(02-27-2012, 02:28 PM)d smith Wrote:
(02-26-2012, 11:50 PM)7estatdef Wrote:  Hi and Welcome to the phourm!
Here's the service info for the model 60.
http://www.nostalgiaair.org/Resources/793/M0013793.htm
Hi Terry,
Thanks so much for this service info ! Do you happen to know if there would have ever been an instruction book for the owner of this radio?
Truly
Dave
There was a 1 or 2 page paper that would show you how to operate the set but it was gotten rid of 80yrs ago. Most folks could figure how to work it without the instructions
That explains why I cant find one then!
Just would have been nice to have seen it though.
Dave
Philco 1934 Model 60mb - by d smith - 02-26-2012, 10:12 PM
RE: Philco 1934 Model 60mb - by 7estatdef - 02-26-2012, 11:50 PM
RE: Philco 1934 Model 60mb - by d smith - 02-27-2012, 02:28 PM
RE: Philco 1934 Model 60mb - by 7estatdef - 02-27-2012, 11:23 PM
RE: Philco 1934 Model 60mb - by d smith - 02-28-2012, 01:24 PM
RE: Philco 1934 Model 60mb - by Steve Davis - 02-27-2012, 02:52 PM
RE: Philco 1934 Model 60mb - by d smith - 02-27-2012, 04:52 PM
Philco 91 Tuning Condenser
There are currently 5963 online users. [Complete List]
» 2 Member(s) | 5961 Guest(s)
