chronic radio interference model 60mb
(02-28-2012, 11:35 PM)7estatdef Wrote:
(02-28-2012, 10:11 PM)d smith Wrote:  Hi I'm currently getting chronic interference on this radio in the morning through midday. cant use radio at all, radio fine at other times......I live next door to a shop where i can only assume this is emminating from. as they prepare food so microwaves will be used etc
. can anyone suggest anything i can do??? to get rid of the interference extremely loud and persistent buzzing sound is all i get on all stations on the dial.
I obviously cannot ask them to stop using their equipment...wouldn't go down too well with them!
Dave
Antenna?? Is your set grounded??
Hi Terry,
I should have mentioned I am a complete novice to this.
This radio, I purchased from the US, I live in the UK, The guy I bought it from fitted a 220v transformer so that the radio could be used in this country.
It has only twin, live and neutral cabling.. Should I earth(ground), the chassis, if so, to which part of the chasis should i ground it and swap to three prong wire.
Terry could you also suggest a book for complete novices like me who wants to learn more, safely, but without blowing myself up!!!
RE: chronic radio interference model 60mb - by d smith - 02-29-2012, 01:05 PM
Philco 91 Tuning Condenser
There are currently 4698 online users. [Complete List]
» 1 Member(s) | 4697 Guest(s)
