Philco 60 resistor wattages?
Here, this might help. http://www.philcorepairbench.com/resistcompare.htm
M R Radios   C M Tubes
Philco 60 resistor wattages? - by lyle - 02-29-2012, 05:20 PM
RE: Philco 60 resistor wattages? - by Steve Davis - 02-29-2012, 05:44 PM
RE: Philco 60 resistor wattages? - by lyle - 02-29-2012, 06:48 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7131 online users. [Complete List]
» 2 Member(s) | 7129 Guest(s)
