39-116 Found?
(03-02-2012, 03:23 PM)ipwizard Wrote:  Ohh come on Ron, it's so much fun sitting there for hours and hours re-wiring a set.Icon_rolleyes Icon_biggrin
I know. Been there, done that multiple times, and as I said in my previous post, I'm getting ready to do all of that again in a 41-616 - miles and miles of the stuff. Icon_mad
39-116 Found? - by Arran - 03-02-2012, 01:52 AM
RE: 39-116 Found? - by Ron Ramirez - 03-02-2012, 09:02 AM
RE: 39-116 Found? - by ipwizard - 03-02-2012, 03:23 PM
RE: 39-116 Found? - by Ron Ramirez - 03-02-2012, 03:44 PM
RE: 39-116 Found? - by Arran - 03-02-2012, 10:01 PM
RE: 39-116 Found? - by 7estatdef - 03-02-2012, 03:59 PM
RE: 39-116 Found? - by Ron Ramirez - 03-02-2012, 04:52 PM
RE: 39-116 Found? - by Doug Houston - 03-03-2012, 01:30 AM
RE: 39-116 Found? - by Arran - 03-03-2012, 02:16 AM
RE: 39-116 Found? - by DeckApe - 03-03-2012, 07:48 PM
Philco 91 Tuning Condenser
