philco 46-1209 help
(03-02-2012, 01:38 PM)D R FORD Wrote:  help plate glow in tube , and need to find tone arm assembly for its record changer a D-10 i think set is all original except for above thanks David
I think I have a extra d-10 changer. If you are interested I will look for it and let you know. It will be the one that uses the crystal pickup not the magnetic pickup
Joe
philco 46-1209 help - by D R FORD - 03-02-2012, 01:38 PM
RE: philco 46-1209 help - by ipwizard - 03-02-2012, 01:58 PM
RE: philco 46-1209 help - by D R FORD - 03-02-2012, 02:09 PM
RE: philco 46-1209 help - by ipwizard - 03-02-2012, 02:59 PM
RE: philco 46-1209 help - by codefox1 - 03-02-2012, 04:00 PM
RE: philco 46-1209 help - by w4rtc - 03-02-2012, 04:04 PM
The speaker table error?
Philco 70 antenna lead
