Part ID help
Hi,
It's a ceramic tubular moulded cap not a resistor. That's why it's "open." Icon_smile
Try it on your cap meter or R-C bridge.
The color code actually reads the other way. It's a 22,000 pF, 20%, 500v. or 0.022 uF/500v
White = Temp coeficient = (+100 to
-750 parts per million per deg C)
Red = 2 (first sig digit)
Red = 2 (sec sig digit)
Yel = x10,000 (multiplier, four zeros)
Black = Tolerance, 20%
Part ID help - by Danny - 11-19-2006, 12:42 PM
[No subject] - by Chuck Schwark - 11-19-2006, 04:23 PM
[No subject] - by Danny - 11-27-2006, 10:26 AM
There are currently 4915 online users. [Complete List]
» 1 Member(s) | 4914 Guest(s)
