Philco 37-660
Thanks to all. Technically I'm a new member because it has been a long time since I logged on and had to re-registor. I used to know where to find the info on the bakelite caps but have forgotten. Can anyone direct me to it? Thanks again. Also thanks for the heads up on the high volatage caps.
Philco 37-660 - by marv - 03-02-2012, 04:56 PM
RE: Philco 37-660 - by Chuck Schwark - 03-02-2012, 05:10 PM
RE: Philco 37-660 - by 7estatdef - 03-02-2012, 05:41 PM
RE: Philco 37-660 - by TA Forbes - 03-02-2012, 06:15 PM
RE: Philco 37-660 - by Arran - 03-03-2012, 12:28 AM
RE: Philco 37-660 - by marv - 03-02-2012, 08:17 PM
RE: Philco 37-660 - by Ron Ramirez - 03-02-2012, 09:09 PM
RE: Philco 37-660 - by marv - 03-03-2012, 04:17 PM
RE: Philco 37-660 - by marv - 03-03-2012, 05:40 PM
RE: Philco 37-660 - by Ron Ramirez - 03-04-2012, 08:31 AM
RE: Philco 37-660 - by Texasrocker - 03-04-2012, 02:56 AM
RE: Philco 37-660 - by marv - 03-14-2012, 04:29 PM
RE: Philco 37-660 - by rghines1 - 03-14-2012, 08:24 PM
RE: Philco 37-660 - by marv - 03-14-2012, 08:50 PM
RE: Philco 37-660 - by codefox1 - 03-15-2012, 01:31 AM
The speaker table error?
Philco 70 antenna lead
There are currently 7681 online users. [Complete List]
» 3 Member(s) | 7678 Guest(s)
