Resistor substitution 20% range?
(03-02-2012, 10:45 PM)codefox1 Wrote:
(03-02-2012, 09:56 PM)7estatdef Wrote:  I'll add to what Codefox sez. Back in the day alot of resistors where standard values now days not all of these older resistors are standard anymore. So you may not be able to find the exact value but bear in mind that back then 20 percent was standard.So you've got a fairly broad range to pick from. WELCOME TO THE PHORUM!!!
Welcome indeed, and most resistors are in fact 5% or better and only a few pennies apiece. If you have an odd value, you can order an assortment to find out which works better with your application or visit Mr. Ohm (Ohm's Las) to parallel or series what you got to what you need. Just be mindfull or lead dress if you start fooling around.
We're here.
Thank you. I can't believe how great you guys are. I really love radios that glow. Don't know why, and don't care. I just want to rescue as many as I can from the dump. Oh sorry, today it's a landfill.
lyle
I may not be very good, but I'm slow.
Resistor substitution 20% range? - by lyle - 03-02-2012, 07:29 PM
RE: Resistor substitution 20% range? - by lyle - 03-02-2012, 09:15 PM
RE: Resistor substitution 20% range? - by lyle - 03-03-2012, 12:52 PM
RE: Resistor substitution 20% range? - by lyle - 03-05-2012, 01:01 PM
RE: Resistor substitution 20% range? - by lyle - 03-03-2012, 12:49 PM
RE: Resistor substitution 20% range? - by Arran - 03-03-2012, 12:18 AM
RE: Resistor substitution 20% range? - by lyle - 03-03-2012, 12:40 PM
RE: Resistor substitution 20% range? - by Arran - 03-06-2012, 12:47 AM
RE: Resistor substitution 20% range? - by lyle - 03-07-2012, 12:35 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7121 online users. [Complete List]
» 1 Member(s) | 7120 Guest(s)
