atwater kent model 70 filter caps
Hi Guy's,
Have picked up a 1930 atwater kent model 70 today.
Guy I bought it from said he replaced all the caps and resistors,but not the filter caps.Guess they checked good.
I did a little research,and apparently these filter caps are non-polarized and mounted inside soldered cans.
Anyone know an easy way to get these cans apart and replace the caps?
Or,should I leave it alone as long as its working good.
Cabinet is in good shape,so I figured it's probably worth the $70 he wants for it.
Thanks
murf
atwater kent model 70 filter caps - by murf - 03-03-2012, 02:36 PM
RE: atwater kent model 70 filter caps - by Arran - 03-04-2012, 02:48 AM
RE: atwater kent model 70 filter caps - by murf - 03-04-2012, 04:36 PM
RE: atwater kent model 70 filter caps - by murf - 03-06-2012, 04:12 PM
RE: atwater kent model 70 filter caps - by Arran - 03-06-2012, 10:51 PM
RE: atwater kent model 70 filter caps - by murf - 09-03-2012, 05:08 PM
Eico 232 VTVM Schematic
There are currently 9022 online users. [Complete List]
» 1 Member(s) | 9021 Guest(s)
