Philco Console 112
I picked a Model 95 Deluxe up for $29, can see at this site, http://home-and-garden.webshots.com/albu...5997PzeVUr which is in great shape except the lower leg areas where bow wow "the bad" decided to chew on it. Great radios nice cabinets, once I find some lower legs I will be on my way.
Philco Console 112 - by radioray - 11-19-2006, 12:33 PM
[No subject] - by Ron Ramirez - 11-19-2006, 03:41 PM
[No subject] - by Drew - 11-19-2006, 05:56 PM
[No subject] - by 49Stude63 - 11-20-2006, 03:52 PM
[No subject] - by Ron Ramirez - 11-28-2006, 09:45 AM
