atwater kent model 70 filter caps
If you have to or decide to restuff the filter can use a toaster oven or a hot plate and bake it out slowly, playing with a propane torch is just asking for trouble you don't need.
atwater kent model 70 filter caps - by murf - 03-03-2012, 02:36 PM
RE: atwater kent model 70 filter caps - by Arran - 03-04-2012, 02:48 AM
RE: atwater kent model 70 filter caps - by murf - 03-04-2012, 04:36 PM
RE: atwater kent model 70 filter caps - by murf - 03-06-2012, 04:12 PM
RE: atwater kent model 70 filter caps - by Arran - 03-06-2012, 10:51 PM
RE: atwater kent model 70 filter caps - by murf - 09-03-2012, 05:08 PM
There are currently 5938 online users. [Complete List]
» 1 Member(s) | 5937 Guest(s)
