atwater kent model 70 filter caps
(03-04-2012, 02:48 AM)Arran Wrote:  If you have to or decide to restuff the filter can use a toaster oven or a hot plate and bake it out slowly, playing with a propane torch is just asking for trouble you don't need.
Thanks for the info Arran,
Think I will leave it alone for now.
Any idea why it won't pick up some of the local stations?
Picks up a few,but not as many as it should.
Is it hard to align this set?
Or is there something else I should be looking at?
Have a great day.
murf
atwater kent model 70 filter caps - by murf - 03-03-2012, 02:36 PM
RE: atwater kent model 70 filter caps - by Arran - 03-04-2012, 02:48 AM
RE: atwater kent model 70 filter caps - by murf - 03-04-2012, 04:36 PM
RE: atwater kent model 70 filter caps - by murf - 03-06-2012, 04:12 PM
RE: atwater kent model 70 filter caps - by Arran - 03-06-2012, 10:51 PM
RE: atwater kent model 70 filter caps - by murf - 09-03-2012, 05:08 PM
There are currently 5827 online users. [Complete List]
» 2 Member(s) | 5825 Guest(s)
