Philco 37-630 veneer question
I am currently working on a 37-630 table model.
I need to replace or patch the thin veneer strips(3 of them) and I am having trouble getting a color match.
Does anyone know what the color was or should I use something close of my choice?
Thanks
Philco 37-630 veneer question - by zimmy1 - 03-04-2012, 05:34 PM
RE: Philco 37-630 veneer question - by TA Forbes - 03-05-2012, 03:48 PM
RE: Philco 37-630 veneer question - by zimmy1 - 03-05-2012, 08:22 PM
RE: Philco 37-630 veneer question - by Arran - 03-06-2012, 12:30 AM
RE: Philco 37-630 veneer question - by TA Forbes - 03-06-2012, 02:34 PM
There are currently 3655 online users. [Complete List]
» 1 Member(s) | 3654 Guest(s)
