Philco 37-630 veneer question
Hello: not sure what you mean here. The 3 "bars" over the speaker?
Usually what is done is a veneer repair and then toner is sprayed to blend the repair to the rest of the surface being sprayed.
On my 630 I had to replace some of the grillework veneer. In order to match the very dark wood "stripes" that go down the center, I first sprayed with clear and then very carefully drew the black lines with a sharpie. THEN I toned over the whole thing. Unless you examine it very carefully, you cannot tell. The reason I sprayed with clear first was to prevent the ink from soaking into the dry wood in the repair and spreading farther than I wanted it to.
Philco 37-630 veneer question - by zimmy1 - 03-04-2012, 05:34 PM
RE: Philco 37-630 veneer question - by TA Forbes - 03-05-2012, 03:48 PM
RE: Philco 37-630 veneer question - by zimmy1 - 03-05-2012, 08:22 PM
RE: Philco 37-630 veneer question - by Arran - 03-06-2012, 12:30 AM
RE: Philco 37-630 veneer question - by TA Forbes - 03-06-2012, 02:34 PM
There are currently 10282 online users. [Complete List]
» 1 Member(s) | 10281 Guest(s)
