Magnavox Regency Symphony 155-B
This is the model that Ron bought a year or more ago. If the set still has the Webster-Chicago 56 changer, or an upgrade of the same model, you have a mighty fine radio there. i also bought a few nice consoles in the last year, though I also am low on space. It's simply an addiction.
Magnavox Regency Symphony 155-B - by rocketeer - 03-04-2012, 09:02 PM
RE: Magnavox Regency Symphony 155-B - by Doug Houston - 03-06-2012, 12:18 AM
RE: Magnavox Regency Symphony 155-B - by Arran - 03-06-2012, 11:01 PM
RE: Magnavox Regency Symphony 155-B - by w4rtc - 03-06-2012, 10:25 PM
RE: Magnavox Regency Symphony 155-B - by w4rtc - 03-07-2012, 12:45 PM
RE: Magnavox Regency Symphony 155-B - by JRATTO1 - 05-08-2012, 05:16 PM
RE: Magnavox Regency Symphony 155-B - by JRATTO1 - 05-09-2012, 05:52 PM
RE: Magnavox Regency Symphony 155-B - by Harry - 06-04-2012, 09:08 PM
Philco 91 Tuning Condenser
There are currently 10135 online users. [Complete List]
» 3 Member(s) | 10132 Guest(s)
