Acoustic clarifier why?
Hey Thanks, Chuck. These things are much more complicated than I imagined.
I do recall though that his radio sounded like crap until the back was in place, then it was like a concert hall!
Interesting those "Accoustic Clarifiers" seem to do for the radio/sound like my "Tuned Bilstein Shocks" do for my off road suspension on my truck.....
Regards, Chuck btw. yours is also a nice web site.
Acoustic clarifier why? - by atwater10 - 11-21-2006, 02:33 PM
[No subject] - by Chuck Schwark - 11-21-2006, 02:39 PM
[No subject] - by atwater10 - 11-21-2006, 06:50 PM
[No subject] - by Tim Tress - 11-27-2006, 11:28 PM
[No subject] - by Chuck Schwark - 11-27-2006, 11:51 PM
[No subject] - by atwater10 - 11-28-2006, 12:56 AM
Philco 91 Tuning Condenser
