atwater kent model 70 filter caps
As far as your reception goes, the 70 has two antenna jacks, one for local and one for distant. One of the toggle switches in the control panel controls which antenna jack the radio is using. I have my antenna hooked up to the distant jack and just listen from there.
atwater kent model 70 filter caps - by murf - 03-03-2012, 02:36 PM
RE: atwater kent model 70 filter caps - by Arran - 03-04-2012, 02:48 AM
RE: atwater kent model 70 filter caps - by murf - 03-04-2012, 04:36 PM
RE: atwater kent model 70 filter caps - by TA Forbes - 03-06-2012, 02:42 PM
RE: atwater kent model 70 filter caps - by murf - 03-06-2012, 04:12 PM
RE: atwater kent model 70 filter caps - by Arran - 03-06-2012, 10:51 PM
RE: atwater kent model 70 filter caps - by murf - 09-03-2012, 05:08 PM
