41-295 Developed Intermittent Crackling
Only 3 mica caps to go? Replace 'em. But only after the gentle tapping and probing with a dry old chopstick reject from the kitchen. I assume that tube pins, sockets and switches have received their once every 50 years Deoxit shower.
Else you may be poking around until next Christmas.
RE: 41-295 Developed Intermittent Crackling - by codefox1 - 03-06-2012, 06:18 PM
The speaker table error?
Philco 70 antenna lead
