Philco 39-30 restoration
#41
(03-06-2012, 05:30 AM)bandersen Wrote:  Sorry. I meant that when using the isolation transformer, grounding the chassis didn't seem to have as much effect. When running the radio straight from the wsll outlet, grounding the chassis helps a lot. I guess I'll have to run a wire from the GND screw on the back to a ground point somewhere in my place when I use it.
This is just a thought but have you tried piggy backing a pair of other caps across the line capacitors to increase the values? At least you figured out that it was power line noise and not something like a wire routed in the wrong place or an open ground connection.
Philco 39-30 restoration - by Bob Andersen - 02-05-2012, 01:39 AM
RE: Philco 39-30 restoration - by Bob Andersen - 02-27-2012, 02:20 AM
RE: Philco 39-30 restoration - by Bob Andersen - 02-28-2012, 12:22 AM
RE: Philco 39-30 restoration - by Ron Ramirez - 02-28-2012, 06:50 AM
RE: Philco 39-30 restoration - by Bob Andersen - 02-28-2012, 06:11 PM
RE: Philco 39-30 restoration - by Arran - 02-29-2012, 02:30 AM
RE: Philco 39-30 restoration - by Bob Andersen - 03-02-2012, 09:59 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-02-2012, 03:55 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-02-2012, 06:08 PM
RE: Philco 39-30 restoration - by Arran - 03-03-2012, 12:23 AM
RE: Philco 39-30 restoration - by Bob Andersen - 03-04-2012, 02:26 AM
RE: Philco 39-30 restoration - by Arran - 03-04-2012, 03:04 AM
RE: Philco 39-30 restoration - by Bob Andersen - 03-04-2012, 03:47 AM
RE: Philco 39-30 restoration - by Ron Ramirez - 03-04-2012, 08:28 AM
RE: Philco 39-30 restoration - by Bob Andersen - 03-04-2012, 04:11 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-04-2012, 10:13 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-05-2012, 11:47 PM
RE: Philco 39-30 restoration - by Arran - 03-06-2012, 12:53 AM
RE: Philco 39-30 restoration - by Bob Andersen - 03-06-2012, 01:40 AM
RE: Philco 39-30 restoration - by Arran - 03-06-2012, 03:45 AM
RE: Philco 39-30 restoration - by Bob Andersen - 03-06-2012, 05:30 AM
RE: Philco 39-30 restoration - by Arran - 03-06-2012, 09:09 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-07-2012, 12:42 AM
RE: Philco 39-30 restoration - by Bob Andersen - 03-13-2012, 08:17 PM
RE: Philco 39-30 restoration - by Arran - 03-13-2012, 11:08 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-16-2012, 11:45 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-30-2012, 10:05 PM
RE: Philco 39-30 restoration - by Ron Ramirez - 03-30-2012, 10:08 PM
RE: Philco 39-30 restoration - by Arran - 03-30-2012, 10:50 PM
RE: Philco 39-30 restoration - by Bob Andersen - 04-06-2012, 06:11 PM
RE: Philco 39-30 restoration - by Ron Ramirez - 04-06-2012, 09:22 PM
RE: Philco 39-30 restoration - by Bob Andersen - 04-07-2012, 12:44 AM
Re: Philco 39-30 restoration - by Arran - 02-05-2012, 02:21 AM
Re: Philco 39-30 restoration - by Bob Andersen - 02-05-2012, 03:09 AM
Re: Philco 39-30 restoration - by Arran - 02-05-2012, 03:20 AM
Re: Philco 39-30 restoration - by Ron Ramirez - 02-05-2012, 09:01 AM
Re: Philco 39-30 restoration - by Bob Andersen - 02-05-2012, 04:31 PM
Re: Philco 39-30 restoration - by Ron Ramirez - 02-05-2012, 06:09 PM
Re: Philco 39-30 restoration - by codefox1 - 02-05-2012, 06:12 PM
Re: Philco 39-30 restoration - by Bob Andersen - 02-05-2012, 06:36 PM
Re: Philco 39-30 restoration - by Arran - 02-05-2012, 10:40 PM
Re: Philco 39-30 restoration - by Bob Andersen - 02-08-2012, 12:18 AM
Re: Philco 39-30 restoration - by codefox1 - 02-08-2012, 11:06 AM
Re: Philco 39-30 restoration - by Bob Andersen - 02-08-2012, 06:15 PM
Re: Philco 39-30 restoration - by Ron Ramirez - 02-08-2012, 06:42 PM
Re: Philco 39-30 restoration - by Bob Andersen - 02-08-2012, 06:50 PM
Re: Philco 39-30 restoration - by Ron Ramirez - 02-08-2012, 09:11 PM
Re: Philco 39-30 restoration - by RGallahue - 02-08-2012, 09:27 PM
Re: Philco 39-30 restoration - by Bob Andersen - 02-08-2012, 11:18 PM
Re: Philco 39-30 restoration - by Bob Andersen - 02-10-2012, 01:03 AM
Users browsing this thread: 13 Guest(s)
The speaker table error?
Philco 70 antenna lead
There are currently 7052 online users. [Complete List]
» 1 Member(s) | 7051 Guest(s)
