Magnavox Regency Symphony 155-B
Wow Larry, the same person must have converted my Regency to a V-M changer...a piece of paneling was also laid over the original opening for the W-C 56 changer, one mounting ear partially cut off, and the V-M changer was put in without being fastened down in any way. There are scars inside the lid where the spindle hit the inside of the lid when it was being moved at some point.
I bought my Maggie from someone in Indianapolis. I think she told us she was from Minnesota, and was moving back. So I don't know if she brought the Maggie with her to Indy, or bought it locally.
Magnavox Regency Symphony 155-B - by rocketeer - 03-04-2012, 09:02 PM
RE: Magnavox Regency Symphony 155-B - by Arran - 03-06-2012, 11:01 PM
RE: Magnavox Regency Symphony 155-B - by w4rtc - 03-06-2012, 10:25 PM
RE: Magnavox Regency Symphony 155-B - by Ron Ramirez - 03-07-2012, 06:43 AM
RE: Magnavox Regency Symphony 155-B - by w4rtc - 03-07-2012, 12:45 PM
RE: Magnavox Regency Symphony 155-B - by JRATTO1 - 05-08-2012, 05:16 PM
RE: Magnavox Regency Symphony 155-B - by JRATTO1 - 05-09-2012, 05:52 PM
RE: Magnavox Regency Symphony 155-B - by Harry - 06-04-2012, 09:08 PM
Philco 91 Tuning Condenser
There are currently 6856 online users. [Complete List]
» 2 Member(s) | 6854 Guest(s)
