Magnavox Regency Symphony 155-B
Same here, the inside of the lid is buggered as well. Interesting how these things move around. I bought this one here in eastern PA but it was originally sold in Charlestown WV. Wouldn't it be interesting if radios could talk and tell you where they've been, what they've seen, and how they got where they are? Icon_smile
Larry
Magnavox Regency Symphony 155-B - by rocketeer - 03-04-2012, 09:02 PM
RE: Magnavox Regency Symphony 155-B - by Arran - 03-06-2012, 11:01 PM
RE: Magnavox Regency Symphony 155-B - by w4rtc - 03-06-2012, 10:25 PM
RE: Magnavox Regency Symphony 155-B - by rocketeer - 03-07-2012, 09:58 AM
RE: Magnavox Regency Symphony 155-B - by w4rtc - 03-07-2012, 12:45 PM
RE: Magnavox Regency Symphony 155-B - by JRATTO1 - 05-08-2012, 05:16 PM
RE: Magnavox Regency Symphony 155-B - by JRATTO1 - 05-09-2012, 05:52 PM
RE: Magnavox Regency Symphony 155-B - by Harry - 06-04-2012, 09:08 PM
Philco 91 Tuning Condenser
There are currently 10119 online users. [Complete List]
» 2 Member(s) | 10117 Guest(s)
