48-200 mystery capacitor
The resistor that is in parallel with the dogbone ceramic 220 pF capacitor is 470K (yellow - violet - yellow).
Look closely. That is a very light violet...almost dark pink...but definitely violet. I've seen old 470K resistors with very light violet bands like this before.
Now if you look above the 220 pF dogbone cap, there is a resistor with an orange band and a silver band; can't make out the other bands. The orange is definitely a different color than the light violet of the 470K resistor.
430K isn't a standard value, and wasn't back then, either...
48-200 mystery capacitor - by winkydink - 03-05-2012, 08:24 AM
RE: 48-200 mystery capacitor - by John R - 03-05-2012, 12:33 PM
RE: 48-200 mystery capacitor - by winkydink - 03-05-2012, 01:13 PM
RE: 48-200 mystery capacitor - by winkydink - 03-06-2012, 05:24 PM
RE: 48-200 mystery capacitor - by planigan - 03-06-2012, 06:00 PM
RE: 48-200 mystery capacitor - by codefox1 - 03-06-2012, 06:14 PM
RE: 48-200 mystery capacitor - by Ron Ramirez - 03-06-2012, 06:35 PM
RE: 48-200 mystery capacitor - by Steve Davis - 03-06-2012, 07:54 PM
RE: 48-200 mystery capacitor - by planigan - 03-07-2012, 12:53 PM
RE: 48-200 mystery capacitor - by Steve Davis - 03-07-2012, 02:42 PM
RE: 48-200 mystery capacitor - by Ron Ramirez - 03-07-2012, 07:46 PM
RE: 48-200 mystery capacitor - by planigan - 03-07-2012, 09:14 PM
RE: 48-200 mystery capacitor - by winkydink - 03-08-2012, 10:43 AM
RE: 48-200 mystery capacitor - by winkydink - 03-08-2012, 11:57 AM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 6860 online users. [Complete List]
» 1 Member(s) | 6859 Guest(s)
