speaker repair
I use tea bags & flexible fabric glue. Cover the area with glue, apply a piece of the bag over the glue then spread glue over it again. Make sure to work out the air bubbles & smooth everything out. If possible, patch both sides of the cone.
speaker repair - by winkydink - 03-08-2012, 10:47 AM
RE: speaker repair - by Glenn Roberts - 03-08-2012, 01:53 PM
RE: speaker repair - by Dave - 03-08-2012, 03:59 PM
RE: speaker repair - by TexMac - 03-09-2012, 03:17 AM
The speaker table error?
Philco 70 antenna lead
There are currently 7441 online users. [Complete List]
» 3 Member(s) | 7438 Guest(s)
