Philco 60 bandswitch replacement
(03-08-2012, 10:02 PM)lyle Wrote:  Hi Guys,
I thought things were going well on this repair until I discovered the bandswitch Bakelite wafer was cracked. I suppose I can replace this with a modern rotory switch. Or can I?
lyle
Well you could find another 60 for parts. I would use some super glue or epoxy to hold it together. You could replace it with a new one but it would have to have arrangement of contacts.
Philco 60 bandswitch replacement - by lyle - 03-08-2012, 10:02 PM
RE: Philco 60 bandswitch replacement - by 7estatdef - 03-08-2012, 10:47 PM
RE: Philco 60 bandswitch replacement - by lyle - 03-08-2012, 11:43 PM
RE: Philco 60 bandswitch replacement - by Arran - 03-08-2012, 11:49 PM
RE: Philco 60 bandswitch replacement - by Arran - 03-08-2012, 10:53 PM
RE: Philco 60 bandswitch replacement - by lyle - 03-08-2012, 11:48 PM
RE: Philco 60 bandswitch replacement - by lyle - 03-11-2012, 11:49 AM
RE: Philco 60 bandswitch replacement - by lyle - 03-30-2012, 07:18 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6683 online users. [Complete List]
» 2 Member(s) | 6681 Guest(s)
