Scored a 41-316RX !
If I had the time, I would do a proper job, but I'm just going to do a quick stain and lacquer. I just want to stabilize and protect the cabinet plus make it look a little nicer. When I have more time, I'll refinish the whole cabinet. The aligatoring on the sides is pretty bad.
As for the hole, the owner said this radio was in an auto garage for much of it's life. Could be that someone used it as a workbench while they drilled a hole in something Icon_sad
Scored a 41-316RX ! - by Bob Andersen - 03-07-2012, 11:24 PM
RE: Scored a 41-316RX ! - by Jayce - 03-08-2012, 12:13 AM
RE: Scored a 41-316RX ! - by Arran - 03-08-2012, 03:56 AM
RE: Scored a 41-316RX ! - by Arran - 03-08-2012, 01:16 AM
RE: Scored a 41-316RX ! - by TA Forbes - 03-08-2012, 05:08 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-08-2012, 05:47 PM
RE: Scored a 41-316RX ! - by Ron Ramirez - 03-08-2012, 08:37 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-08-2012, 09:25 PM
RE: Scored a 41-316RX ! - by Arran - 03-08-2012, 10:40 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-09-2012, 05:59 PM
RE: Scored a 41-316RX ! - by Arran - 03-09-2012, 09:42 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-09-2012, 11:58 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-10-2012, 08:47 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-11-2012, 03:13 AM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-11-2012, 03:27 AM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-16-2012, 05:04 PM
RE: Scored a 41-316RX ! - by Ron Ramirez - 03-16-2012, 07:10 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-16-2012, 11:52 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-19-2012, 03:30 PM
RE: Scored a 41-316RX ! - by Doug Houston - 03-19-2012, 07:59 PM
RE: Scored a 41-316RX ! - by Arran - 03-20-2012, 01:02 AM
RE: Scored a 41-316RX ! - by Ron Ramirez - 03-19-2012, 10:05 PM
RE: Scored a 41-316RX ! - by Arran - 03-20-2012, 01:12 AM
RE: Scored a 41-316RX ! - by TA Forbes - 03-20-2012, 10:56 AM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-19-2012, 11:37 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-21-2012, 12:17 AM
RE: Scored a 41-316RX ! - by Arran - 03-21-2012, 08:47 PM
RE: Scored a 41-316RX ! - by w4rtc - 03-21-2012, 12:05 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-21-2012, 01:23 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 03-22-2012, 05:56 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 04-03-2012, 04:10 PM
RE: Scored a 41-316RX ! - by Ron Ramirez - 04-03-2012, 09:33 PM
RE: Scored a 41-316RX ! - by Bob Andersen - 06-18-2015, 04:41 PM
RE: Scored a 41-316RX ! - by Warren - 06-18-2015, 10:42 PM
Users browsing this thread: 21 Guest(s)
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3507 online users. [Complete List]
» 3 Member(s) | 3504 Guest(s)
