Philco 90 1st IF xfrmr question
Discovered that the 1st IF transformer in the Philco 90 early model I am restoring is open on the primary side. Does anyone know if there are any suitable replacements on other Philco models? The secondary reads ~65 ohms, I assume that the primary was the same, as the xfrmr links two 24 tubes.
Philco 90 1st IF xfrmr question - by TA Forbes - 03-10-2012, 01:01 AM
The speaker table error?
Philco 70 antenna lead
