Magnavox Regency Symphony 155-B
Ron;
I saw a Regency-Symphony in the flesh last year. I failed to notice the grille cloth, but if our buddy here says that his appears original, and has a sort of understated vertical rib, that's probably the answer. I wonder how similar the prewar ReGency grille cloth is to the one after the war ??????? That one's in pretty nice shape.
Thee prewar Belvedere that I bought a few months ago still has a couple of small patches of grille cloth left. Somebody's Kitty-cat must have had a fun time with the grille cloth. I still have that accursed cast on my right foot. I hope to have it off within a couple of weeks. I have a list a block long, of things I need to get done. Lots of stuff on each of the cars.
Magnavox Regency Symphony 155-B - by rocketeer - 03-04-2012, 09:02 PM
RE: Magnavox Regency Symphony 155-B - by Arran - 03-06-2012, 11:01 PM
RE: Magnavox Regency Symphony 155-B - by w4rtc - 03-06-2012, 10:25 PM
RE: Magnavox Regency Symphony 155-B - by w4rtc - 03-07-2012, 12:45 PM
RE: Magnavox Regency Symphony 155-B - by Doug Houston - 03-10-2012, 11:39 PM
RE: Magnavox Regency Symphony 155-B - by JRATTO1 - 05-08-2012, 05:16 PM
RE: Magnavox Regency Symphony 155-B - by JRATTO1 - 05-09-2012, 05:52 PM
RE: Magnavox Regency Symphony 155-B - by Harry - 06-04-2012, 09:08 PM
Philco 91 Tuning Condenser
There are currently 10293 online users. [Complete List]
» 2 Member(s) | 10291 Guest(s)
