Philco 60 bandswitch replacement
Hi, Arran.
Used superglue and a bead of epoxy along the break.
If there is a 'next time' I'd try some Plas-T-Pair. Have repaired Bakelite tube bases with it and got a really strong bond.
Anyway, band selector is fixed and was able to give it a good cleaning while it was in pieces and out of the radio.
I actually found a copy of 'Elements of Radio Servicing' among some old radio books I bought on ebay years ago.
Will use it as my textbook. Thanks for reminding me.
lyle
lyle
I may not be very good, but I'm slow.
Philco 60 bandswitch replacement - by lyle - 03-08-2012, 10:02 PM
RE: Philco 60 bandswitch replacement - by lyle - 03-08-2012, 11:43 PM
RE: Philco 60 bandswitch replacement - by Arran - 03-08-2012, 11:49 PM
RE: Philco 60 bandswitch replacement - by Arran - 03-08-2012, 10:53 PM
RE: Philco 60 bandswitch replacement - by lyle - 03-08-2012, 11:48 PM
RE: Philco 60 bandswitch replacement - by lyle - 03-11-2012, 11:49 AM
RE: Philco 60 bandswitch replacement - by lyle - 03-30-2012, 07:18 PM
91H Code 126 Restore
Philco 70 antenna lead
