Philco 90 Filter Cap Can Question?
Thank you! I was doing some digging around on the internet and found a Philco 90 that had these cans on it. Does the top of this can come off? It doesn't appear to have been soldered on. I ask because I'd like to restuff this one and hopefully find another one to restuff. I really like things original. The bottom of this one has what appears to be a bakelite base with the threads on it for the nut. So I can't go in through the bottom.
Pepper
"It's Nice To Be Nice To The Nice"
Major Frank Burns Mash 4077th
Philco 90 Filter Cap Can Question? - by Pepperoni - 03-10-2012, 06:13 PM
RE: Philco 90 Filter Cap Can Question? - by Pepperoni - 03-11-2012, 01:35 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 5895 online users. [Complete List]
» 1 Member(s) | 5894 Guest(s)
