Philco 90 Filter Cap Can Question?
Refer to this link from the Philco Repair Bench site. It is exactly how I re-stuff them. The only thing I do differently is, after the mershon is "gutted," I try to gently tap the metal screw through the plastic insulation until it falls out. Be careful, as it is very soft metal. If I can do this, I clean the inside end with a small wire brush, drill a small hole through it, and secure/solder the positive end of the replacement cap to it. This allows you to re-stuff without drilling a hole in the plastic for the positive end of your replacement cap.
http://www.philcorepairbench.com/tips/svctip45.htm
Philco 90 Filter Cap Can Question? - by Pepperoni - 03-10-2012, 06:13 PM
RE: Philco 90 Filter Cap Can Question? - by TA Forbes - 03-11-2012, 02:58 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
