Philco 38-9
Ron,
Will have to double check when I get home. I probably wrote the number down wrong.
thanks
Chris
Philco 38-9 - by Chris Drumma - 11-27-2006, 08:47 AM
[No subject] - by Ron Ramirez - 11-27-2006, 09:06 AM
[No subject] - by Chris Drumma - 11-27-2006, 10:42 AM
[No subject] - by Chris Drumma - 11-28-2006, 09:06 AM
[No subject] - by batterymaker - 11-30-2006, 11:17 AM
[No subject] - by Chris Drumma - 11-30-2006, 12:13 PM
[No subject] - by batterymaker - 11-30-2006, 04:46 PM
[No subject] - by Chris Drumma - 12-01-2006, 08:41 AM
Eico 232 VTVM Schematic
There are currently 9670 online users. [Complete List]
» 1 Member(s) | 9669 Guest(s)
