Magnavox Regency Symphony 155-B
Here's a pic of the backside of my grille cloth. As you can see it's not really a vertical rib pattern but more a cross-hatch however, I've examined the wood trim that holds it in and it does not appear to have ever been removed. Dunno. Icon_confused
[Image: http://i863.photobucket.com/albums/ab191...ckside.jpg]
Larry
Magnavox Regency Symphony 155-B - by rocketeer - 03-04-2012, 09:02 PM
RE: Magnavox Regency Symphony 155-B - by Arran - 03-06-2012, 11:01 PM
RE: Magnavox Regency Symphony 155-B - by w4rtc - 03-06-2012, 10:25 PM
RE: Magnavox Regency Symphony 155-B - by w4rtc - 03-07-2012, 12:45 PM
RE: Magnavox Regency Symphony 155-B - by rocketeer - 03-12-2012, 09:56 AM
RE: Magnavox Regency Symphony 155-B - by JRATTO1 - 05-08-2012, 05:16 PM
RE: Magnavox Regency Symphony 155-B - by JRATTO1 - 05-09-2012, 05:52 PM
RE: Magnavox Regency Symphony 155-B - by Harry - 06-04-2012, 09:08 PM
Philco 91 Tuning Condenser
There are currently 8782 online users. [Complete List]
» 2 Member(s) | 8780 Guest(s)
