HEY Ron
I got that portable I got from you, 39-72, playing ,turned out to be more of a job than I first thought it would be, All the tubes where burned out! someone must have use the wrong "A" voltage, but the original tubes where long and skinny, the replacements I had the cut down the base to get them to fit! Anyways Ive still was able to use the original tube shields and it plays great !It's surpriseing how good this little four tube sets can work
HEY Ron - by BILL - 03-12-2012, 10:41 AM
RE: HEY Ron - by Ron Ramirez - 03-12-2012, 03:49 PM
RE: HEY Ron - by BILL - 03-13-2012, 09:44 AM
RE: HEY Ron - by Ron Ramirez - 03-13-2012, 10:01 AM
RE: HEY Ron - by Arran - 03-13-2012, 07:03 PM
RE: HEY Ron - by BILL - 03-13-2012, 06:36 PM
RE: HEY Ron - by Ron Ramirez - 03-13-2012, 07:17 PM
RE: HEY Ron - by Arran - 03-17-2012, 02:40 AM
RE: HEY Ron - by Arran - 03-13-2012, 07:25 PM
Philco 91 Tuning Condenser
There are currently 5826 online users. [Complete List]
» 3 Member(s) | 5823 Guest(s)
