new fm?
(03-14-2012, 09:16 PM)LASJayhawk Wrote:  check out the converters section of this website. Has sone info about how they did it after WWII
http://www.somerset.net/arm/fm_only.html
Very cool thank you!
new fm? - by fixinmyphilco - 03-11-2012, 11:17 AM
RE: new fm? - by Ron Ramirez - 03-11-2012, 11:55 AM
RE: new fm? - by fixinmyphilco - 03-11-2012, 12:01 PM
RE: new fm? - by Ron Ramirez - 03-11-2012, 01:02 PM
RE: new fm? - by fixinmyphilco - 03-11-2012, 01:05 PM
RE: new fm? - by 7estatdef - 03-11-2012, 08:59 PM
RE: new fm? - by LASJayhawk - 03-14-2012, 09:16 PM
RE: new fm? - by fixinmyphilco - 03-14-2012, 09:40 PM
The speaker table error?
Philco 70 antenna lead
