Model TH-1 Investigation solved!!!
Quoting from Ron's description : "Could this be Simplex Radio Company (referring to the S.R.C. on the tag) and was this the TH-1 a Simplex-designed set? This possibility remains under investigation" Reading this we understand that Ron knows the answer but does not have conclusive evidence to back it up. This radio proves his theory. This is also why I added that it was a somewhat rhetorical question but thanx for your concern....
RE: Model TH-1 Investigation solved!!! - by Arran - 03-15-2012, 12:13 AM
RE: Model TH-1 Investigation solved!!! - by PHILLYPHILCO - 03-15-2012, 06:39 PM
Philco 91 Tuning Condenser
There are currently 4724 online users. [Complete List]
» 1 Member(s) | 4723 Guest(s)
