Cleaning Philco 90 Volume Control
When a control gets really bad I carefully open them up and clean the resistive element and the wiper by dipping it in varsol to get rid of grease and then with rubbing alcohol to get rid of any oil left behind. Sometimes the shaft is stiff and I have to undo the "C" clip holding it in, clean the shaft and bushing, and regrease the bushing. Don't try any of is if you think you may loose or break something.
Cleaning Philco 90 Volume Control - by Sourbone - 03-15-2012, 02:58 PM
RE: Cleaning Philco 90 Volume Control - by morzh - 04-01-2012, 11:28 PM
RE: Cleaning Philco 90 Volume Control - by Arran - 03-16-2012, 08:42 PM
RE: Cleaning Philco 90 Volume Control - by morzh - 03-18-2012, 01:43 PM
RE: Cleaning Philco 90 Volume Control - by morzh - 03-19-2012, 01:56 PM
RE: Cleaning Philco 90 Volume Control - by morzh - 03-21-2012, 06:58 PM
RE: Cleaning Philco 90 Volume Control - by John R - 03-21-2012, 07:46 PM
RE: Cleaning Philco 90 Volume Control - by morzh - 04-03-2012, 10:03 PM
RE: Cleaning Philco 90 Volume Control - by morzh - 04-09-2012, 08:56 PM
RE: Cleaning Philco 90 Volume Control - by morzh - 04-09-2012, 09:24 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7130 online users. [Complete List]
» 3 Member(s) | 7127 Guest(s)
