Threads: 42
City: Chicago, IL
Three 80s in a row in Chicago! Normally, I'd be doing a lot of soldering this time of year instead of refinishing.
Almost done. Just waiting on some mica caps and for the lacquer to cure. Then I'll affix the new plastic dial face and grille cloth.
[Image: http://farm8.staticflickr.com/7061/68427...2c69_z.jpg]
(This post was last modified: 03-16-2012, 11:47 PM by Bob Andersen.)
RE: Philco 39-30 restoration - by Bob Andersen - 03-16-2012, 11:45 PM
>>and found that the field coil is bad. Should be 1140 ohms, tests at 1.1k ohms.
You have one stringent crit...morzh — 02:07 PM |
Yes I was there. I got some real bargains there. Plus a Zenith 7G605 clipper that I have been trying to find for a fair ...Radios1340 — 01:46 PM |
The speaker table error?
G 10-1/2" 65, 76, 87, 95
Push-Pull 45's
2766
0.7
550
3200
H 10-1/2" 77, 96
Push-Pull...morzh — 09:26 PM |
I have a Stromberg, one of the early ones, seems early 30s.
This is what I call a back breaker. None of the early Philc...morzh — 08:28 PM |
A backbreaker.....PaulPaul Philco322 — 08:12 PM |
>>What a behemoth!
A Juggernaut.morzh — 07:47 PM |
Philco 70 antenna lead
I am not sure I understood about the coils and the mush. I looked an more than one coil in 20, 70, 90, 60, Zeniths and ...morzh — 07:46 PM |
:e_biggrin: What a behemoth! I hope the final result is as much a quality sounding example! Keep us posted on your pro...GarySP — 07:32 PM |
I should add that the double conversion may only be used on the shortwave bands, but I haven't looked at the schematic t...Arran — 07:27 PM |
Yes, that wire will not pick up much interference as routed - the RF at that level won't be affected, and if you have st...radio1 — 07:26 PM |
There are currently 7033 online users. [Complete List] » 1 Member(s) | 7032 Guest(s)
