smoke escaping from resistors
OK finally an update. Had a chace to power up with the field coil plugged in, no more smoke. It appears that this was causing the load on #7. However no sound or hum. Now that I can power up and leave the power on, I will check voltages and it looks like I have a tube or two that may be questionable. Now all I need is some time.
smoke escaping from resistors - by raydog - 03-10-2012, 05:13 PM
RE: smoke escaping from resistors - by rghines1 - 03-10-2012, 07:56 PM
RE: smoke escaping from resistors - by Arran - 03-10-2012, 08:21 PM
RE: smoke escaping from resistors - by raydog - 03-11-2012, 03:33 PM
RE: smoke escaping from resistors - by raydog - 03-12-2012, 08:32 AM
RE: smoke escaping from resistors - by 7estatdef - 03-12-2012, 04:42 PM
RE: smoke escaping from resistors - by rghines1 - 03-12-2012, 05:24 PM
RE: smoke escaping from resistors - by Arran - 03-13-2012, 06:54 PM
RE: smoke escaping from resistors - by codefox1 - 03-12-2012, 04:50 PM
RE: smoke escaping from resistors - by raydog - 03-12-2012, 07:13 PM
RE: smoke escaping from resistors - by raydog - 03-14-2012, 07:39 PM
RE: smoke escaping from resistors - by morzh - 03-17-2012, 06:41 PM
RE: smoke escaping from resistors - by Arran - 03-17-2012, 10:36 PM
RE: smoke escaping from resistors - by raydog - 03-18-2012, 10:20 AM
RE: smoke escaping from resistors - by morzh - 03-18-2012, 11:20 AM
RE: smoke escaping from resistors - by Arran - 03-19-2012, 12:29 AM
RE: smoke escaping from resistors - by morzh - 03-19-2012, 01:51 PM
RE: smoke escaping from resistors - by raydog - 03-18-2012, 02:55 PM
RE: smoke escaping from resistors - by raydog - 03-20-2012, 01:06 PM
RE: smoke escaping from resistors - by morzh - 03-20-2012, 09:28 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7401 online users. [Complete List]
» 3 Member(s) | 7398 Guest(s)
