37-116 automatic tuning dial woes
Clear packing tape works fine for me. I just stick on the back side of the dial.
37-116 automatic tuning dial woes - by LASJayhawk - 03-14-2012, 12:04 AM
RE: 37-116 automatic tuning dial woes - by Arran - 03-14-2012, 12:32 AM
RE: 37-116 automatic tuning dial woes - by 7estatdef - 03-21-2012, 08:00 AM
The speaker table error?
Philco 70 antenna lead
