Philco 80 Jr, just starting....
hey Terry
Thanks for advice. No I don't want to change grid leak resistor, it is 11.4K i/o 10K, and I think it is fine the way it is; the cap is mica and is probably OK.
And the radio works, so it needs some tuning but nothing drastic.
Interesting, I used one of the original #36 tubes (another one was cooked, the filament's gone), and it did work, but I made a smart choice of buying two tested tubes, and, after the radio worked, I tried the original; it did work in the Det.-Osc. stage, I saw no difference in amplification, but it did not work in the Second detector (regenerative); I could barely hear anything.
Judging by sound, the Audio is OK.
Actually the grid leak is the 3 or 4 meg resistor in the grid circuit.
Philco 80 Jr, just starting.... - by morzh - 01-28-2012, 09:35 PM
RE: Philco 80 Jr, just starting.... - by morzh - 02-29-2012, 12:21 AM
RE: Philco 80 Jr, just starting.... - by morzh - 03-15-2012, 12:05 AM
RE: Philco 80 Jr, just starting.... - by codefox1 - 03-15-2012, 01:25 AM
RE: Philco 80 Jr, just starting.... - by morzh - 03-15-2012, 10:44 AM
RE: Philco 80 Jr, just starting.... - by codefox1 - 03-15-2012, 12:20 PM
RE: Philco 80 Jr, just starting.... - by morzh - 03-17-2012, 01:14 AM
RE: Philco 80 Jr, just starting.... - by morzh - 03-21-2012, 03:35 PM
RE: Philco 80 Jr, just starting.... - by 7estatdef - 03-21-2012, 07:07 PM
RE: Philco 80 Jr, just starting.... - by morzh - 03-21-2012, 11:03 PM
RE: Philco 80 Jr, just starting.... - by morzh - 03-21-2012, 10:56 PM
Re: Philco 80 Jr, just starting.... - by morzh - 01-29-2012, 03:24 PM
Re: Philco 80 Jr, just starting.... - by morzh - 02-05-2012, 06:23 PM
Re: Philco 80 Jr, just starting.... - by morzh - 02-06-2012, 06:31 PM
Re: Philco 80 Jr, just starting.... - by morzh - 02-11-2012, 08:25 PM
Re: Philco 80 Jr, just starting.... - by codefox1 - 02-11-2012, 09:50 PM
Re: Philco 80 Jr, just starting.... - by morzh - 02-12-2012, 11:14 PM
Re: Philco 80 Jr, just starting.... - by codefox1 - 02-13-2012, 04:22 PM
Re: Philco 80 Jr, just starting.... - by morzh - 02-13-2012, 06:37 PM
Re: Philco 80 Jr, just starting.... - by morzh - 02-15-2012, 12:50 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 7067 online users. [Complete List]
» 1 Member(s) | 7066 Guest(s)
