philco model 60
Hi
No, the 42 audio output does not require a tube shield. Icon_smile
In the model 60, only the 6A7 det-osc tube, the 78 IF tube and the 75 2nd det tube used tube shields. And in later 1936 versions of the 60, the 6A7 did not use a shield.
The shields are very important, however, on the 78 and 75 tubes, The radio will squeal badly without them.
philco model 60 - by d smith - 03-21-2012, 06:59 PM
RE: philco model 60 - by Ron Ramirez - 03-21-2012, 07:33 PM
RE: philco model 60 - by d smith - 03-21-2012, 07:52 PM
RE: philco model 60 - by 7estatdef - 03-21-2012, 08:06 PM
RE: philco model 60 - by d smith - 03-21-2012, 09:39 PM
RE: philco model 60 - by TA Forbes - 03-21-2012, 11:22 PM
RE: philco model 60 - by d smith - 03-24-2012, 03:01 PM
RE: philco model 60 - by tab10672 - 03-24-2012, 05:18 PM
RE: philco model 60 - by d smith - 03-24-2012, 09:45 PM
Philco 91 Tuning Condenser
There are currently 4581 online users. [Complete List]
» 2 Member(s) | 4579 Guest(s)
